Old 09-12-2006, 09:54 PM
monte55 is on a distinguished road
Mach 3 and Windows XP
Does Mach 3 have problems running on Windows XP? I have to buy a new computer to run this program and it will come with XP. Any comments welcome. Anyone have suggestions on minimum computer requirements to run Mach 3?
Nick
Old 09-12-2006, 10:21 PM
ger21's Avatar
It ONLY runs on XP and Windows 2000. XP Home or Pro doesn't matter. Minimum recommended is about 1Ghz. I'd recommend at least a 2Ghz. Also, get 1Gig of RAM.
A lot of people on the mach support groups have had good luck with the cheap Dell's. Make sure whatever you buy has a parallel port.
Old 09-12-2006, 11:17 PM
Thanks man, I appreciate the quick reply!!!!!!!!! Nick
Old 09-13-2006, 06:15 AM
Gold Member
HillBilly is on a distinguished road
But not XP 64 pro.
Darek
Old 09-13-2006, 08:34 AM
bill south's Avatar
bill south is on a distinguished road
Hey Gerry (and gang);
At this poing in time I'm only running with 500 meg of ram with a 2.5 gig processor. Is the extra 500 worthwhile????
I've thought of upgrading (not to expensive) but was wondering if it made any difference in a benchtop cnc mill ap.
Thx!
Bill
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 09-13-2006, 11:38 AM
ger21's Avatar
If you run large g-code programs it might help. If you don't have any problems, it probably won't make a difference.
Old 10-18-2006, 07:14 PM
out**cold is on a distinguished road
I was going to try Mach3 myself . the system I have is only 700MHz and 256mg of ram. It has XP. Will this be a problem?? can I run Mach2 with XP?
Old 10-18-2006, 08:07 PM
ger21's Avatar
You'll have to try it and see. You can install both Mach2 and Mach3 on the same PC and try both. Just don't try and run them at the same time. Download them both and see how they work for you.
Old 10-18-2006, 08:28 PM
Gold Member
JFettig is on a distinguished road
I currently run mach2 on 650mhz laptop decently, previously on a 700 and 900mhz celeron decently, the 900mhz celeron went up to 45000khz on mach2 but couldnt do it on mach3.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
