Old 12-15-2003, 02:36 PM
kong is on a distinguished road
mach2 home switches
I've just downloaded the demo of Mach2, having just set my home switches up for emc - nc switches wired in series to one input. I just can't figure out how to get all of the axes to home. I can see the button that says "ref all" which sends all axes to home, but when one hits it's switch, mach2 thinks they are all at home. Is there a ref x or ref y button somewhere?!
Old 12-15-2003, 07:19 PM
balsaman's Avatar
balsaman is on a distinguished road
My home switches are working. Mine are NO. Perhaps you need to change that in the software somewhere (uncheck active low?). I don't see a ref x, y, z. I also can't figure out how to send an axis to a location...
Eric
I wish it wouldn't crash.
Old 12-15-2003, 09:53 PM
HuFlungDung's Avatar
Moderator
I am not sure how you have your machines set up, but logically, the setup is impossible if you are calling your home position that location where the switch opens. You should not. You should home to a given number of steps from where the switch changes state again. This will allow the continuity of the circuit to home another axis in sequence.
For machines with encoders, they never home on something as crude as a switch opening. That is merely a signal to mark the approximate position, after which the encoder index is sought in a given range from the switch break.
Old 12-15-2003, 10:59 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Kong, I have attached some setup screen shots of my Mach 2 setup. Look over the screen shots and compair them to yours.
Name:	03 ports-pins.jpg‎
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 12-15-2003, 11:00 PM
HomeCNC's Avatar
Next one.
Also check out the Mach 2 PDF manual
Name:	05 ports-pins.jpg‎
Old 12-15-2003, 11:21 PM
balsaman's Avatar
Hu,
You are correct that the best way is to use the encoder's marker pulse for homing after you hit a home switch. I think there is a circuit for doing that on the CAD_CAM yahoo site. It's just another thing on my to do list that will never get done!
Eric
Old 12-16-2003, 08:34 AM
Thanks guys, I've wired each one on a seperate pin now, so they work ok when I use "ref all". Balsaman, the only way I can see to send an axis to a location is to use the MDI screen to input a seperate line of g-code. I'm liking this software now, will purchase at the weekend I think.
Just out of interest, what sort of pulse stream should I expect to get from an AMD 500Mhz pc, as the demo is limited to 25000Hz.
Old 12-16-2003, 12:22 PM
balsaman's Avatar
Are you sure? I thought it was user selectable. Up to 35000 hz...
Maybe you are right. 25 khz is enough for my machine.
My Pll 233 puts out the 25 khz no problem.
Hey this is my 1000th post! You guys must be sick of my rambling. LOL
Eric
Old 12-16-2003, 12:32 PM
Eric
yawns, only joking!
Seriously, the demo will allow you to change the settings, but they seem to have no effect. In the motor tuning screen, the max speed stays the same. I can remeber reading this somewhere too. My machine requires 9500ish pulses per inch/second.
Old 12-16-2003, 01:21 PM
HomeCNC's Avatar
Balsaman,
I was wondering the date you would hit 1000 posts. Wow you do talk alot
I thought you were using TurboCNC not Mach 2.
Old 12-16-2003, 01:40 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Kong -
My PIII/500hz machine "seemed" to be ok at 35000. I say "seemed" as I was trying to work some motor problems - steps lost/gained and thought a re-tune would be usefull to explore all rates and pulse width allternatives. BUT - the problem seems to really be the motors. All indications were the system was running at 35,000 +/- but the symptoms remained the same- so off for another set!
Jim
  #12   Ban this user!
Old 12-16-2003, 02:05 PM
HighSeas, it's probably no help, but I have just read about on-board graphics interupting the pulse-stream. It seems in the older systems these graphics chip sets may have a higher system priority than Mach2, which I take it may cause lost steps or jerkiness in motion. Just a thought.
Limit and home switches EMC and Mach2? ESjaavik LinuxCNC (formerly EMC2) 4 09-29-2008 11:39 AM
How do you hook up limit and home switches? CNCadmin DeskCNC Controller Board 6 09-23-2007 04:34 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 02:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 07:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 06:32 PM
