Old 05-10-2006, 06:14 PM
SgtClassman is on a distinguished road
Help
i have mach 3 and i got a g-code loaded and i can run it in offline mode to make sure everything is ok and when i turn the off line mode off it wont let me reset it says external estop what is that
Old 05-10-2006, 07:00 PM
ger21's Avatar
Go to Config>ports and pins>Inputs. Find the E-stop pin, and change the "active low" setting.
