Old 03-01-2003, 01:38 PM
len len is offline
len is on a distinguished road
How do you ?
How do I convert DXF to gcode using Mach1?
Old 03-01-2003, 05:56 PM
Scott is on a distinguished road
DXF to G-code
Len
I have never gotten the converter in Mach1 to work. I convert it in Master5 and run it in Mach1. That seems to work well.
Scott
Old 03-01-2003, 08:12 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Does Mach1 use layers?
Old 03-02-2003, 08:08 AM
Art Fenerty's Avatar
Art Fenerty is on a distinguished road
DXF->GCode
The dxf-> GCode in Mach1 is the same as Master5. You select import... and then load the dxf file. You set parameters such as "as drawn" to keep coordinates the same as the DXF, or don't select it to set the coordinate base to 0,0,0.
Select the depth of the z when cutting and select the feedrate during a cut.
Then select import. In Mach1, the system wil immediately ask for a G-Code file name for the new G-Code, it will then load the file after conversion.
www.gearotic.com
Art Fenerty
Old 03-02-2003, 08:09 AM
Oh, Mach1 does not use layers as yet. It also cannot do 3d dxf's. That remains for a future version...
www.gearotic.com
Art Fenerty
Old 03-31-2003, 12:14 PM
CNCadmin's Avatar
Site Owner
Is the new Mach out yet?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
