| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
#13
| Did you use a 1/8" tool? Maybe your steps/inch are set incorrectly.
#14
| Yes 1/8" tool. Step/unit calculated 5/16-18 threaded rod 1/18=.0556" per rotation . Using 1/4 micro stepping for 800 steps per rotation so 800*18= 14400 steps per inch which come out to be 14400 steps = 1.0008" I think I could live with 8 ten thousandths. I will measure movement with a dial indicator to be sure 14400 steps moves 1"... it it doesn't how can I correct it? |
#16
| It's not a question of moving 10 inches and back. That should always be the same unless you're missing steps. You need to know, if you move 10 inches, does it really move 10 inches. A simple test is to cut a smal square and measure with a caliper. Something like: G0 Z1 G0 X1 Y1 G1 Z-.125 G1 X5.125 Y1 G1 X5.125 Y5.125 G1 X1 Y5.125 G1 X1 Y1 G0 Z1 With a 1/8" tool, does this give you a 4" square?
#18
| I think so. Try it and see.
#19
| After a couple of cut, measure, adjust steps/unit I am within +.001 - .001 which for a homemade wooden cnc router...... I am happy with. BUT and everybody has a but I still can't get cutter compensation to work right ![]() Downloaded sheetcam got the temp license file manually walking thru mapping it out seeing how it works. |
#20
#21
| I think you posted this code.. I changed G42P0.0752 (instead of .0625) and I can get the part to come out correct. I see with Sheetcam it just codes the part with the step in it IE on the notches it cuts from the edge in then steps over .075 and cuts back out. Too late to try this tonight (Kids asleep and the router is LOUD *grin*). How loud is the Hitachi router my old Crapsmen is a SCREAMER. Just thought of something.. I will rotate the part and see if the notches turn out right. OR cut it REALLY to check for slop G40 M3 G0 Z0.1250 G0 X4.2500 Y2.8750 Z0.1250 G1 X4.2500 Y2.8750 Z0.0000 F50 G2 X4.2500 Y2.8750 Z-0.1250 I0.0000 J-0.1250 F150 G2 X4.2500 Y2.8750 Z-0.2500 I0.0000 J-0.1250 G2 X4.2500 Y2.8750 Z-0.2800 I0.0000 J-0.1250 G0 X4.2500 Y2.8750 Z0.1250 G0 X4.2500 Y8.3750 Z0.1250 G1 X4.2500 Y8.3750 Z0.0000 F50 G2 X4.2500 Y8.3750 Z-0.1250 I0.0000 J-0.1250 F150 G2 X4.2500 Y8.3750 Z-0.2500 I0.0000 J-0.1250 G2 X4.2500 Y8.3750 Z-0.2800 I0.0000 J-0.1250 G0 X4.2500 Y8.3750 Z0.1250 G0 X2.7500 Y2.8750 Z0.1250 G1 X2.7500 Y2.8750 Z0.0000 F50 G2 X2.7500 Y2.8750 Z-0.1250 I0.0000 J-0.1250 F150 G2 X2.7500 Y2.8750 Z-0.2500 I0.0000 J-0.1250 G2 X2.7500 Y2.8750 Z-0.2800 I0.0000 J-0.1250 G0 X2.7500 Y2.8750 Z0.1250 G0 X2.7500 Y8.3750 Z0.1250 G1 X2.7500 Y8.3750 Z0.0000 F50 G2 X2.7500 Y8.3750 Z-0.1250 I0.0000 J-0.1250 F150 G2 X2.7500 Y8.3750 Z-0.2500 I0.0000 J-0.1250 G2 X2.7500 Y8.3750 Z-0.2800 I0.0000 J-0.1250 G0 X2.7500 Y8.3750 Z0.1250 G0 X1.0000 Y10.7063 Z0.1250 G1 X1.0000 Y10.7063 Z0.0000 F50 G42P0.0752 G1 X2.0000 Y10.2063 Z-0.1250 F150 G1 X2.0000 Y9.2500 Z-0.1250 G1 X2.1425 Y9.2500 Z-0.1250 G1 X2.1425 Y7.3525 Z-0.1250 G1 X3.5000 Y7.3525 Z-0.1250 G1 X3.5000 Y7.1475 Z-0.1250 G1 X2.1425 Y7.1475 Z-0.1250 G1 X2.1425 Y3.8525 Z-0.1250 G1 X3.5000 Y3.8525 Z-0.1250 G1 X3.5000 Y3.6475 Z-0.1250 G1 X2.1425 Y3.6475 Z-0.1250 G1 X2.1425 Y1.7500 Z-0.1250 G1 X2.0000 Y1.7500 Z-0.1250 G1 X2.0000 Y1.0000 Z-0.1250 G1 X2.9185 Y1.0000 Z-0.1250 G2 X4.0815 Y1.0000 Z-0.1250 I0.5815 J0.0000 G1 X5.0000 Y1.0000 Z-0.1250 G1 X5.0000 Y1.7500 Z-0.1250 G1 X4.8575 Y1.7500 Z-0.1250 G1 X4.8575 Y1.8975 Z-0.1250 G1 X3.5000 Y1.8975 Z-0.1250 G1 X3.5000 Y2.1025 Z-0.1250 G1 X4.8575 Y2.1025 Z-0.1250 G1 X4.8575 Y5.3975 Z-0.1250 G1 X3.5000 Y5.3975 Z-0.1250 G1 X3.5000 Y5.6025 Z-0.1250 G1 X4.8575 Y5.6025 Z-0.1250 G1 X4.8575 Y8.8975 Z-0.1250 G1 X3.5000 Y8.8975 Z-0.1250 G1 X3.5000 Y9.1025 Z-0.1250 G1 X4.8575 Y9.1025 Z-0.1250 G1 X4.8575 Y9.2500 Z-0.1250 G1 X5.0000 Y9.2500 Z-0.1250 G1 X5.0000 Y10.0000 Z-0.1250 G1 X4.0815 Y10.0000 Z-0.1250 G2 X2.9185 Y10.0000 Z-0.1250 I-0.5815 J0.0000 G1 X1.7500 Y10.0000 Z-0.1250 G40 G1 X1.3750 Y10.2500 Z0.0000 G0 X1.3750 Y10.2500 Z0.1250 G0 X1.0000 Y10.7063 Z0.1250 G1 X1.0000 Y10.7063 Z0.0000 F50 G42P0.0625 G1 X2.0000 Y10.2063 Z-0.2500 F150 G1 X2.0000 Y9.2500 Z-0.2500 G1 X2.1425 Y9.2500 Z-0.2500 G1 X2.1425 Y7.3525 Z-0.2500 G1 X3.5000 Y7.3525 Z-0.2500 G1 X3.5000 Y7.1475 Z-0.2500 G1 X2.1425 Y7.1475 Z-0.2500 G1 X2.1425 Y3.8525 Z-0.2500 G1 X3.5000 Y3.8525 Z-0.2500 G1 X3.5000 Y3.6475 Z-0.2500 G1 X2.1425 Y3.6475 Z-0.2500 G1 X2.1425 Y1.7500 Z-0.2500 G1 X2.0000 Y1.7500 Z-0.2500 G1 X2.0000 Y1.0000 Z-0.2500 G1 X2.9185 Y1.0000 Z-0.2500 G2 X4.0815 Y1.0000 Z-0.2500 I0.5815 J0.0000 G1 X5.0000 Y1.0000 Z-0.2500 G1 X5.0000 Y1.7500 Z-0.2500 G1 X4.8575 Y1.7500 Z-0.2500 G1 X4.8575 Y1.8975 Z-0.2500 G1 X3.5000 Y1.8975 Z-0.2500 G1 X3.5000 Y2.1025 Z-0.2500 G1 X4.8575 Y2.1025 Z-0.2500 G1 X4.8575 Y5.3975 Z-0.2500 G1 X3.5000 Y5.3975 Z-0.2500 G1 X3.5000 Y5.6025 Z-0.2500 G1 X4.8575 Y5.6025 Z-0.2500 G1 X4.8575 Y8.8975 Z-0.2500 G1 X3.5000 Y8.8975 Z-0.2500 G1 X3.5000 Y9.1025 Z-0.2500 G1 X4.8575 Y9.1025 Z-0.2500 G1 X4.8575 Y9.2500 Z-0.2500 G1 X5.0000 Y9.2500 Z-0.2500 G1 X5.0000 Y10.0000 Z-0.2500 G1 X4.0815 Y10.0000 Z-0.2500 G2 X2.9185 Y10.0000 Z-0.2500 I-0.5815 J0.0000 G1 X1.7500 Y10.0000 Z-0.2500 G40 G1 X1.3750 Y10.2500 Z0.0000 G0 X1.3750 Y10.2500 Z0.1250 G0 X1.0000 Y10.7063 Z0.1250 G1 X1.0000 Y10.7063 Z0.0000 F50 G40 G1 X1.3750 Y10.2500 Z0.0000 G0 X1.3750 Y10.2500 Z0.1250 G0 X0 Y0 M5 M30 |
