Results 1 to 4 of 4
Thread: encoder question
    Mar 2006
    Post encoder question
    Before I waste countless hours making adapters to mount encoders on my stepping motors does anyone know if the Mach 3 takes into consideration the backlash of an axis when calculating the distance travelled by the encoder? Thank you.
    If it doesn't work BUY BIGGER MOTORS!!
    Mar 2003
    Shelby Twp, MI....USA
    It doesn't calculate anything. All Mach3 does is display the encoders position.
    Mar 2006
    so mach 3 directly displays the position of the encoder? So if this is the case then it would not take into consideration backlash correct?
    Mar 2003
    Correct, it will only display the encoders actual position.
