| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| View Poll Results: Should Mach Software Support SPI? | |||
| Yes | | 12 | 100.00% |
| No | | 0 | 0% |
| Other(post in thread) | | 0 | 0% |
| Voters: 12. You may not vote on this poll | |||
Hey guys, I don't know what Art thinks, because he realy doesnt post in the threads that ask, but maybe this will intice him if he gets a turnout. Tom from Rutex only realy has this to say: "I don't really know what Art will do with the "spi" but Vladimir believes that Art will have reasons to impliment it once it is available through an easy to use DLL." I think it will be a great addition and may even increase sales of Mach software. So what do you all think? Should he support SPI? Jon
__________________ CNC Mini Lathe Plans and Rotary Table kits: http://jfettigmachines.com |
| That would be awsome if he supported it. I personaly own some rutex boards. It would make his product more flexable and probably get more sales. personaly I think its a mistake to team up with one servo driver manufacturer no matter how good they are. Some people will want different packaging (personaly not a fan of little black box technology) and go elsewhere for no other reason. And then there is the specific work envelope of the driver (ie you might want or need a higher current or voltage ). And Of course the money issue, you might want an ebay find.
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| Art's not supporting any certain drives. Mach3 sends step and direction signals, Mach4 does the same thing, it just uses the G-rex for much better performance. You can still use any step and direction drives with the G-Rex. You can't expect a one man operation to support every option out there. Now if I buy 5 R2030's for my motors, and Art supporting SPI means I won't need a G-Rex, then I'm all for it. ![]() I'm curious how many Rutex users there are vs Gecko users? Probably a much smaller market.
| its probably a smaller market on the zone for sure. But then the DIY'ers on the Zone are almost exclusively price driven. I think rutex definitely has a following out on the comericial end of things. But I think gecko is a larger Company and probably has many distributers. I know I have seen gecko look alikes that are probably geckos repackaged by gecko for an Machine manufacturer.
| I was told that Marrise designed his drivers while working for a company called Centent, and at some point went off on his own with a similar looking line of products. Ive bought a bunch of Centents off ebay for nothing, they look exactly like geckos and have nearly identicle specs. New England Affiliated Tech. also has the same package. Whats a trip is that a Centent costs 500.00, last I checked. I have 6 or 7 of the Centent stepper drives, but I have yet to start using them, other than verifying operation.
__________________ Halfnutz (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
SPI and it's sibling I2C was designed for inter board communications as in multifunctional chips in a TV or video which need to exchange setup data. At my work I have designed and implemented I2C on a large system where we go of-board trough ribbon cables in a A very noisy environment. Although we have made it work reliably it takes a lot of effort especially of the cabling is not defined. In noisy environments (heavy motor currents) I would opt for CAN bus (and have done so on our last project) or USB (also used in a noisy environment)and or Ethernet, all are differential transmission layers which are a lot more robust when it comes to electrical noise. The last thing you want is a run-away controller as it miss-read a byte of data my 2 p worth |
| well if you can use spi for the setup and tune with all the prep that we put into it I would assume you could get it to work with the Mach control. But I am not an expert (or even a novice for that matter )
| I fail to see why he should. It's Art's software and he is the most accomodating software developer I have ever worked with. If he wants to he will add it in, if he doesn't, then he probably has a really good reason for it. Perhaps if you explain WHY it should be added and what it's advantages are, then I might understand why the request is even being made. Right now, I don't see any reason to have such a capability. |
#10
| Well golly gee maybe I will explain for the impaired. why should he? because there are people asking. And Yes he is accomodating. But He also got his start from DIY'ers Which (i know) is a very small market. Now he is hooked up with a commerical vendor for drives(gecko) and we are hoping he is still helping the little guys.
As far as what advantages: maybe none but also maybe a fast growing market share. Its hard to tell the future, you just make your stuff to do the best with the most and hope it takes off. I appoligize for my rant but you set me off man!
#11
Ah yes, I can now see why Art should be so accomodating to people like you. Just because someone wants something is reason enough for someone else to do work. Well, I still don't understand, but then again I don't have to, I am not the guy that is being requested to do work for nothing in return. Although I guess I am just too "imparied" to understand these sorts of things. Ah heck, who am I kidding, I am too impaired to even walk and chew gum at the same time Good luck with that! Chris |
#12
