Old 02-11-2006, 11:59 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Lightbulb Sharing one Comp for Mill and Turn?
Has any one here shared the same computer and control box (I mean drives and all) to control a Mill and Lathe? I have a cnc'd Bport and next to it is a lathe so instead of building another computer and control box I want to share it. Any thoughts if there could be problems software wise?
Dennis
Old 02-12-2006, 07:45 AM
ger21's Avatar
When you install Mach3, it gives you icons all set up for mill and lathe. Each has it's own settings, so just set up each one, and run the appropriate one for the machine. You can set up as many machines on one PC as you want, just create a new profile for each.
Old 02-12-2006, 01:52 PM
kdoney is on a distinguished road
I switch to several machines (lathe, mill, router, sander, painter) with one controller.
Old 02-12-2006, 02:18 PM
vmax549 is on a distinguished road
Dennis the EASIEST way that I have found is to setup (2) 2 port LPT cards.( I use 2 ports for each machine) 1 going to each machine hookup. In mach set up each machine for the ports and pins 1 setup in mill for the mill and 1 setup in turn for the lathe. Now when you load mill or turn it is ready to go. you do not have to move,reset,retune anything. Works well for me. (:~)= Terry
Old 02-12-2006, 07:35 PM
ger21's Avatar
Great tip Terry. Would have never thought of that.
Old 02-12-2006, 08:47 PM
DennisCNC's Avatar
Thanks for the info!! Time to start putting things together!
Dennis
Old 02-22-2006, 12:36 AM
Jay Kyle is on a distinguished road
Can you run the mill and lathe simultanously with the one computer?
Old 02-22-2006, 11:52 AM
Hum??? I don't think so, BUT it might be possible if you were to open two sessions of mach at the same time. The problem with that is Timing issues. Two sessions of mach running at the same time might start a wild CAT FIGHT over timing issues and crash mach and your parts/machines and YOU. If you try it do so with great CAUTION. Terry
Old 02-22-2006, 08:18 PM
Well, given the low cost of computers these days, it sounds like the simplest and safest option is to have 2 separate trimmed down computers (small footprint) just for these applications.
Old 02-22-2006, 08:23 PM
ger21's Avatar
You can't run 2 instances of Mach at the same time.
