  #13   Ban this user!
Old 09-05-2003, 06:25 PM
tsalaf is on a distinguished road
I just started using DeskART with Turbocnc and having the same problem. The depth of the image is inverted. All the low spots are high. Everything else I cut with Gcode from VisualMill works fine.
Any ideas?
Steve
  #14   Ban this user!
Old 09-06-2003, 12:36 AM
jimini is on a distinguished road
You could invert your image before you have Deskart creat G code
That should work...................Jim
  #15   Ban this user!
Old 09-06-2003, 02:19 AM
engraver is on a distinguished road
Jim,
I had the same idea, your suggestion is simple and goes around all the tech mambo jambo. Any other simple idea how to get Mach2 to read files 2 to 4 Mb size?
engraver
Old 09-06-2003, 10:59 AM
HuFlungDung's Avatar
Moderator
If it is a software issue, then complain to the developer about it. Most programmers are only too happy to fix what is not working right.
  #17   Ban this user!
Old 09-06-2003, 09:44 PM
It looks I would have to wait till the author fix the issue.
engraver
Engraving Software The Wizard General CAM Discussion 31 03-29-2005 05:38 AM
Mach2 remembering position after shutdown..how does it know Moondog Mach Software (ArtSoft software) 10 02-14-2005 08:56 AM
Windows XP or Windows 2000 better with Mach2 Beezer Mach Software (ArtSoft software) 2 10-18-2004 10:08 AM
Mach2 Faro Arm Inverse Kinematics vacpress General CAM Discussion 7 05-28-2004 09:14 AM
G Code and Mach2 InventIt DIY-CNC Router Table Machines 8 03-13-2004 01:46 PM
