Old 12-06-2005, 08:05 PM
johnd is on a distinguished road
Limit Switch Problems
I have just completed a retrofit of a cincinatti bed mill. The conversion consisted of rutex product ( 2020 boards and Mboard) and a used pentium computer. Windows was upgraded from millenium to XP. The limit switches are tied into the rutex board and work properly. If I enable the switches through Mach2 software I get random faulting. If I disable the switches in the software (all axis ) I have no problems. One thing I noticed was the driver test results (OCX) appeared rough compared to the sample screen in the manual. Is there a listing of what things to look for ? Any help is appreciated.
Thank you
John D.
Old 12-06-2005, 09:36 PM
ger21's Avatar
You might want to go throught the Optimization file at http://www.machsupport.com
(at the bottom)
Try increasing the Input Debounce for the limit switch issue. In Config>Logic.
Old 12-06-2005, 10:04 PM
mikie is on a distinguished road
yep, i used the debounce to fix my issue, i set it 1000 i think. this was arts recommendation. I'll inform you if i have made a mistake with the value
