Results 1 to 6 of 6
Thread: Letters Backwards
    Registered LouF's Avatar
    Sep 2011
    Question Letters Backwards
    Hi I loaded a file into Mach3 from Vetric Cut2D and all the letters are coming out backwards anyone know what may be causing this?
    Thanks Lou
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
    Mar 2003
    Shelby Twp, MI....USA
    One of the axis on your machine is set up backwards.
    Sep 2011
    Gerry thanks I will check it out..
    Lou
    Sep 2011
    Question
    I checked movement the DRO's show that I am moving the right direction it homes to the right location but the lettering is coming out reversed or a mirrored anyone know how to solve this problem?
    Lou
    Mar 2003
    Yes, your machine is backwards.
    Stand at your machine so X+ moves to your right, and X- to your left. When you move in the Y+ direction, it should move away from you. I bet it's moving toward you.
    I've seen this many times, and in all cases the machine is moving in the wrong direction. Homing direction has nothing to do with being set up properly.
    Sep 2011
    Red face
    Gerry, Thanks you are right I have it backwards Damn..
    Lou
    1. Z axis is backwards?
      By RedCoder in forum Benchtop Machines
      Last Post: 12-20-2010, 01:48 PM
    2. backwards G19
      By chippah in forum Vertical Mill, Lathe Project Log
      Last Post: 07-28-2010, 10:59 AM
    3. A Backwards request here...
      By Jasonixo in forum Employment Opportunity
      Last Post: 05-08-2006, 02:28 PM
    4. What are my Z & Y axis going backwards?
      By scheek in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-13-2006, 10:37 PM
    5. Searching Backwards
      By jonbanquer in forum Fadal
      Last Post: 07-28-2003, 07:53 PM
