Results 1 to 4 of 4
Thread: Encoder setup in Mach3
    Apr 2008
    I'm putting encoders onto my steppers, does mach3 stop and alarm if the motor's dont reach the positions Mach has sent them to ? is there a check position routine in Mach3 ?
    Mar 2003
    Shelby Twp, MI....USA
    Mach3 has no built in functions to do this, but you could write a macro or possibly a brain to do it.
    I believe the Verify function checks position by homing the machine and seeing if the machine has lost position since the previous homing routine.
    Apr 2008
    Ah ok then, so best to buy that encoder interface board then as I've no idea how to writing code for Mach.... Cheers thats answered my question....
    Jul 2011
    India
    If you know PLC programming then have a look at brains and modbus interfacing. it's similar to ladder logic and it will sound, halt, tool change etc. whenever you want. You may simply play with your machines configuration.
  1. Need Help!- Encoder interface for Mach3
    By ishman in forum Mach Software (ArtSoft software)
    Last Post: 04-18-2012, 12:19 PM
  2. Setting up mach3 with linear encoder?
    By alex781 in forum Mach Software (ArtSoft software)
    Last Post: 05-31-2011, 09:37 PM
  3. servo encoder signal as DRO in mach3
    By abomination in forum Mach Mill
    Last Post: 05-26-2011, 07:35 AM
  4. Mach3,macros,encoder.
    By Alexf2a in forum Mach Wizards, Macros, & Addons
    Last Post: 02-15-2010, 01:43 PM
  5. Spindle encoder setup
    By R.thayer in forum Controller & Computer Solutions
    Last Post: 03-03-2009, 12:57 PM
