Results 1 to 4 of 4
Thread: Encoder interface for Mach3
    Jul 2011
    India
    I am looking to buy rogersmachine Encoderboard to close the loop with my AC servo motors and drives with mach3. But before I proceed, I have two questions and I need help from you people. PLEASE !!!
    1- My stock servo drives have differential encoder while the interface card as linked above is single ended. is it alright if i connect differential encoder to single ended interface ?
    2- If it's not a good idea to connect differential encoder with single ended interface card then I would have to buy an expensive Hicon CPU from vital systems. BUT, is mach3 capable to handle differential encoder ?
    Thanks in advance
    Mar 2003
    Shelby Twp, MI....USA
    The rogers encoder interface will really not gain you anything if you're using servos.
    All it will do is stop the machine if it loses position.
    Your servo drives should fault if they lose position, which is basically the same thing.
    Jul 2011
    India
    Quote Originally Posted by ger21 View Post
    Thanks !!!
    My servo drive should fault means it's not necessary to feed the position feedback to mach3 ? And the drive will correct the position itself ?
    Jul 2011
    India
    One more thing please, that what to check in servo drive manual to see whether it's having this function or not ?
  1. MACH3 closed loop encoder interface
    By RomaxxCNC in forum Product and Manufacturer Announcements
    Last Post: 05-28-2010, 06:59 PM
  2. 4-axis Mach2/3 Encoder Interface
    By 15mgtar in forum Stepper Motors and Drives
    Last Post: 09-03-2009, 11:49 AM
  3. Sound Logic Encoder Interface anyone?
    By DennisCNC in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2006, 10:50 PM
  4. Help w/ Sound Logic Encoder Interface, Does Anyone Use This Thing??
    By bill south in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 04-25-2006, 08:33 AM
  5. Sound Logic Encoder Interface
    By bill south in forum Gecko Drives
    Last Post: 01-31-2006, 10:22 AM
