Results 1 to 7 of 7
Thread: Mach 3 Pausing after every arc and line while in CV mode?
    Jul 2007
    Scotland
    A little back ground info on my machine....
    I have a large Multicutter 8000, 3 axis router ( 3m * 4m ) bed size. The gantry weights around 700kg. Its rack & pinion x and y and a ball screw on the z.
    Im using granite devices servos drives to drive the original 20 year old west amp servo motors. Everything is working well when the machine is running slowly, the problems arise when I crank up the feed speeds to anything above 1000 mm/min.
    The problem: The motors stops for a split second after most arcs and lines, causing the heavy gantry to stutter and jerk. An example would be a circle made up of 4 arcs, after each quarter the motor will jerk as it moves onto the next line of g-code. Rapidly moving the gantry back and forward with the arrow keys on my keyboard does not cause any jerking or vibration, so it looks to be software based rather than a mechanical errors causing the roughness of movement.
    Another example would be an arc made up of small lines for every line mach3 stops moving just enough to cause vibration and jerking.
    I have CV mode engaged, I have also tried turning it off in mach using the g64 (or is it G68?) command to turn it back on when it starts the g-code.
    In the config settings I have all the CV options turned off, CV Feedrate is also turned off, look ahead is set to 200 steps I have also tried increasing this to 1000 and everywhere inbetween with no luck.
    An ideas and thoughts welcome
    Gav
    Mar 2003
    Shelby Twp, MI....USA
    Do you have backlash comp enabled?
    Jul 2007
    Scotland
    Hi Gerry yes backlash enable has always been off. Just ran my circle test piece again @ 2000mm/min everything fine. @ 4000mm/min big jerk at two quadrants of the circle, always at the same spot.
    Jul 2007
    Scotland
    I may have found a solution to this?
    To increase my feed speeds I was using the feed speed adjuster on the mach3 main page, to get 4000mm/min I was increasing the feed rate up to 200% of the rate in the gcode. For one reason or another this seems to be the cause of the juddering. Could this be right? Anyone else noticed this before?
    Mar 2009
    Angry Bolomill
    I have the same problem since I change the conputer and lost the configuration. I try diferents motor configurations , with not much diference. stil got the jerk after every block.
    Also need help.
    Guillermo.
    Mar 2009
    I finally solve my problem with Mach3 jerking at the end of every block. Change the computer and everything worked . The old computer was runing out of memory.
    Mar 2003
    Quote Originally Posted by gavztheouch View Post
    Yes, it's a known issue.
    Programming for 4m/min and running at 100% will run smoother than 2M/min at 200% override. It's best to not use more than 150% overrride.
    1. Need Help!- Problem with Mach jerking and pausing with Backlash enabled
      By cjdavis618 in forum Mach Software (ArtSoft software)
      Last Post: 05-24-2012, 07:12 AM
    2. mach 3 cv mode stalling
      By ihavenofish in forum Mach Software (ArtSoft software)
      Last Post: 03-04-2012, 11:13 AM
    3. Problem- Mach 3 slow movement Jog, ok Auto Mode
      By cjchands in forum Machines running Mach Software
      Last Post: 12-20-2011, 08:04 AM
    4. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
      By sunmix in forum Servo Motors and Drives
      Last Post: 10-26-2008, 04:53 AM
    5. Single line mode works well, Auto is not soo good??
      By Darc in forum CamSoft Products
      Last Post: 10-26-2004, 04:29 PM
