yup, that what i have been using too. I use a 128meg version tho. The one i have can be found at walmart for under $20. Sure beats using floppys!
http://www.walmart.com/catalog/produ...uct_id=2680550
Catch22 had the idea a USB data key would be good for transfaring .tap files from the computer you design and make the .tap to the machine shop for the computer running Mach3
I just tried it; works great; a 256mg key would most likely be all you'd ever need
Cost me $40 with tax
Yeah they are great, If you ever tried a transfer of a graphic to Gcode file you will apperciate the size over a floppy
I have been using mine ever since I upgraded to mach, I have only had a floppy and cdrom hooked up for the install. I have a usb hub on the outside of my cases for hooking up keyboards, mice, and usb flash drives.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Nothing beats the network...
Chris![]()
CNC Darren,
The best price seen for a USB thumb drive I found is at Sam's Club.
1GB for $59.87
http://www.samsclub.com/eclub/main_s...cfkjdgoodfkg.0
Wayne Hill
Wayne Hill, they go for cheaper than that, and for G-code, you dont need 1gb. I use a 256 stick for mine and has been doing great, the other day a buddy of mine picked up a 1gb stick for $39 at officemax. If you really want a deal, just check the ads. Newegg.com is another good one to watch.
Jon
That 1Gb must have been on sale for $39.00.
http://www.officemax.com/max/solutio...ID=-1610650037
Yes, 256Mg is plenty big for CNC files.
Been reading up on how to access the USB memory drive with DOS.
I'll be trying it soon.
Wayne
Wayne Hill
Try here for usb with DOS
http://www.bootdisk.com/usb.htm
Originally Posted by WayneHill
