Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 45
Thread: New computer, new problems
  1. #25
    Registered neilw20's Avatar
    Jun 2007
    SATA drives should be no problem.
    Disconnect any IDE stuff. CD/DVD rom.
    Or disable in the BIOS, at least.
  2. #26
    Mar 2011
    Quote Originally Posted by neilw20 View Post
    I unpluged the IDE CD ROM drive.. tested and got the same results... Starts out fine then starts stuttering after 30 or so seconds...
  3. #27
    Jun 2007
    In Mach3 config increase lookahead to say 100 or 200.
    The low level queue might be running out of data.
    You can monitor queue depth on the diagnostics page.
    I assume you are using Mach3 above version 3?
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  4. #28
    Mar 2011
    Im not sure if the look ahead is relevant seeing how I'm using the Xbox 360 controller controlling movement for testing.
    Yes. Im using above v3.
  • #29
    Jun 2007
    Mach3 feeds data to the driver via a queue.
    Mach3 upper level program gets a look in about 10 times a second, and if the low level queue is depleted while moving move stops instantly. - The jerk.
    Are you running 25KHZ?
    You might be running it too fast. The queue empties too quickly.
    Only run just fast enough so that you get the required speeds.
  • #30
    Mar 2011
    Im running it at 35000 as it was when I was using the much slower, much less ram, much less video card, etc and it ran great.. So strange... I've tried it at 25,000 before I started posting here. It didn't help either. Its got to be one little setting somewhere...
    It does act like some sort of a buffer is filling up because if I stop movement for a while and start again the problem is gone for another 20 30 seconds...
    I will try setting the read ahead buffer when I get home tonight.
  • #31
    Jun 2007
    Study the Mach3 mysteries PDF. The clues are in there somewhere.
    My machine still has the jerks, and I just lowered the max feed rate so the steppers can stop instantly and not lose position.
    I will fix or upgrade one day. I just ignore the clunk. The 2000 hours running the machine was more important, as was not losing steps.
    Yep, I fixed it the 'other' way.
    If you change the KHz you need to restart Mach3 for it to take affect. See Mach3 manual and read details on clock rate setting.
  • #32
    Mar 2011
    But see, this was running great on a much older machine. it just don't make sense. Maybe ill put xp on another partition and see if its the OS that is the problem.
  • #33
    Jun 2007
    You can do that.
    Might be easier to plug in another drive that already has XP on it from another computer.
    At least it will prove whether it is the OS or the motherboard.
    Try some bios setting that don't use the interrupts on the the parallel card. It is polled anyway by the driver.
    Interrupts will only screw it up (IMHO)
    The clu is it starts doing it 30 seconds later. Watch the diagnostics screen in Mach3 for clues.
    Does it do it in a program or just from the keyboard?
    Make sure sticky keys is disabled. That steals Mach3 keyboard focus. Quite dangerous.
    start button, type sticky and select change how your keyboard works.
    Are you using a wireless keyboard? Latency can be there.
  • #34
    Mar 2011
    What exactly will I be looking for on the diagnostic screen?
  • #35
    Jun 2007
    Queue depth, buffer load, Time in int. Look ahead.
    Any of above getting to a limit, or zero might give a hint.
    Slow the feed. and watch.
    Double the feed and watch.
    Below a certain speed the jerks might smooth out.
    You don't by any chance have exact stop turned on do you?
    That might appear like jerks. It will stop start at all speeds.
  • #36
    Mar 2011
    Ok... man this sucks... Here is what I've found.
    Queue depth stayed 0
    buffer load stayed 0
    time in int was 4 to 6 with peaks of ~15 or less
    Set Look ahead to 200
    Same numbers at various speeds.
    I'm not sure where the 'exact stop' setting is but i'm sure i'm not looking at this as being the problem as it never was before.
    I'm getting pretty frustrated at this point...
    ill post a video if needed.
  • Page 3 of 4 FirstFirst 1234 LastLast
    1. TNC150-computer link problems.
      By mossy in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 04-30-2011, 10:09 AM
    2. What is the difference between an industrial computer and a normal computer?
      By Apples in forum Controller & Computer Solutions
      Last Post: 09-18-2008, 05:27 PM
    3. Need Help!- Compumill 1500 CNC Vertical Mill - Computer problems
      By rondawg333 in forum General Metal Working Machines
      Last Post: 09-06-2008, 01:14 PM
    4. Computer Help
      By jamesr in forum Surfcam
      Last Post: 08-25-2006, 09:36 AM
    5. fast computer as server, slow computer as terminal
      By replicapro in forum Computers and Networking
      Last Post: 07-01-2004, 03:05 PM
