Results 1 to 2 of 2
Thread: Problems with Mach3 Jogging.
    Dec 2011
    united states
    im having a problem with jogging using mach 3. i would use the arrow keys to jog the x and y axis. right and left key to jog the x axis and up and down key to jog the y. When i first boot my comp and launch the program, everything will jog fine, but later on, i would press just 1 key and it will jog both axis's. Anyone have any clue whats wrong here?
    May 2008
    I had a problem like this where sometimes I'd press an arrow key to jog in the X- or X+ direction and the machine would continue in a different direction when repressing the same arrow key.
    Shielded cabling solved the problem.
    HTH
  1. Fanuc 10T problems with jogging
    By an0n in forum Fanuc
    Last Post: 03-06-2012, 04:12 AM
  2. Jogging control problems with Mach3
    By steve-broad in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2012, 06:47 PM
  3. Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 01:12 AM
  4. Problem- Mach3 Arc Problems
    By dynamotive in forum Mach Software (ArtSoft software)
    Last Post: 12-12-2009, 06:49 PM
  5. Programming Mach3 by just jogging the axes manually
    By uplb in forum Mach Software (ArtSoft software)
    Last Post: 11-14-2008, 09:06 PM
