Is this in LazyCAM, or an old version of Mach3?
What it does is create g-code to do a 3D carving of the image.
Depending on your settings, it can take a very long time.
Mach3,Import BMP/JPEG?
I load a basic JPEG and it says "convert", I do this and nothing happens....well something happens but it takes forever and a day and by this time I give up and cancel the convert.
Doesn't even do a simple box of lines.
Whats happenin guys?
Ok,Gerry,I fugured it will need some really large hardrive space? even the simplest imported file was taking forever.
Tsk!
Getting to know Mach3 ie see how things work in the program with mock drive connected setup.
Mach won't let me load a 2d DXF files,BMP and JPG loads.
whats up here?
You didn't answer my first question above. Is this LazyCAM, or an old version of Mach3?
The .dxf import listed in the manual has been removed, and replaced with LazyCAM.
Sorry about that,Ger
So I need Lazycam working alongside Mach3?
I downloaded Mach from artsoft so I'm assuming its the new version?.
Yes, LazyCAM installs with mach3 (if you let it) and does the importing/g-code creation. It's buggy, and unfinished, and I'd highly recommend a more polished CAM program.But many people use it regularly, once they get used to it.
Oh I have one o those,GerryI'd highly recommend a more polished CAM program.
MastercamX but I was just trying to get me head round Mach3 and all its parameters.
Cheers.
Importing .bmp and .dxf is not what Mach3 does.
Load some g-code into Mach3 and go from there.
