| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
If i was to get the new G-Rex controller, using mach4 would i be able to get away with using a much slowerPC than usual? I have a 200MMX with 32meg ram running Windows 98. I know this PC will not work when trying to get the max speed(feed rate) with Mach3. I was hoping the new Grex could act as a buffer to allow use of a cheap PC instead of the need for a new 2Ghz p4. Can anyone confirm it does indeed do this? |
| Mach 3/4 will only work with Windows XP for starters. Art has said that mach4 requires less performance out of the computer. Therefore you should be able to use it on a computer with less than the current minimum requirement of a 1 Gig processor fro mach 3. Note: Mach 4 has not yet been released, and there is only a alpha version currently availiable. Alpha, not even Beta. So beware. |
| Mach3 can work with as little as a 500Mhz PC. Mach4 should be similar, but it needs XP or Win2K. More is recommended, though. Realistically, with drives and motors, a Mach4 / Grex system is going to cost close to $1000. Spend $300 more and get a new PC to run it.
| What I meant to say was, no, the 200MMX won't work. You can pick up a 1Ghz PC on Ebay for ~$100, if you're lucky.
