| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I searched high and low for any type of setup instructions for setting up Mach 3 on my Sherline mill but could not find anything. I tried some XML files I found in various places but I am not having any luck. Using the XML files I am not getting any movement. I have Mach 3 running on a clean install of windows with the stock Sherline driver box. Thanks, Theblah I seem to have gotten the pins and ports correct but now I am having troubles with the motor tuning. When I turn the steppers on all I hear is a humming sound. Last edited by theblah; 01-05-2012 at 11:31 PM. |
Or do they just sit there and hum? If so, what makes you think the pin-out is correct? If they turn at all, you can tune them by varying the velocity and accelleration values until they work optimally, then derate them about 15% as a safety margin. Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
Parameters: ∙ Logic high levels should be greater than 2 volts. ∙ Logic low should be less than 1/2 volt. ∙ Step pulses are active low. ∙ Step pulses should be at least 22 microseconds long. ∙ The lines labeled as EMC inputs or outputs can be disregarded in other systems. ∙ For use with software other than EMC, make sure your software addresses the correct I/O lines for step and direction as shown below. Sherline is not able to provide assistance for other programs. For help with the EMC software, see LinuxCNC.org ∙ We recommend at least an 800 MHz Pentium class computer or faster for use with the frequency mode. In operation, the power to the motors will be reduced to half current after 3 seconds of inactivity. This can be changed to 1/4 power with a jumper on H1. DB25 pin out: 1 - Input from EMC (may be ignored in other systems) 2 - X Direction 3 - X Step 4 - Y Direction 5 - Y Step 6 - Z Direction 7 - Z Step 8 - A Direction 9 - A Step 10 - NC 11 - Output to EMC (may be ignored in other systems) 12 - Output to EMC, XYZ home (may be ignored in other systems) 13 - NC 14 - Input from EMC, C1 (may be ignored in other systems) 15 - NC 16 - Input from EMC, C2 (may be ignored in other systems) 17 - NC 18-25 - Ground Assuming all that's set correctly, did you set your parallel port mode to EPP in BIOS? Are you sure all the wires in your DB-25 cable go all the way through? Are the step pulses set to "active low" and do you have the pulse durations set long enough? Are you sure your system's not in e-stop? Mach normally wants a signal from the emergency stop circuit before it will move the motors. Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
| It looks like everything's correct, except that your step pulses (at the bottom of that last screen) are set to 1 microsecond. Try changing that to 3, and see if anything improves. Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
#10
Are they perhaps too big for this controller? Are you sure they're wired correctly? Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
| Need Help!- Sherline Mill setup and adjustment | Yotamkasam | Mini Lathe | 2 | 01-16-2011 04:52 AM |
| anyone have any info on this setup? sherline 5400 | simila95 | Benchtop Machines | 4 | 08-18-2010 06:33 AM |
| DESK CNC / Sherline Lathe SETUP HELP | GLMS | Benchtop Machines | 0 | 11-04-2009 08:10 AM |
| Highly upgrade Sherline CNC Mill setup | David Da Costa | EBAY ADS | 0 | 10-25-2009 04:26 PM |
| My Sherline CNC Setup | tauscnc | Benchtop Machines | 9 | 02-20-2005 03:05 PM |
