Old 01-05-2012, 08:51 AM
Jkountz is on a distinguished road
Controlling porter cable 7518 speed
Is it possible to control the variable speed of a Porter Cable 7518 router with Mach?
Old 01-05-2012, 10:50 AM
ger21's Avatar
You can do it with a Super PID.
CNC4PC has some options that might work, but the SuperPID is a better choice imo.
Old 01-06-2012, 07:22 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Porter Cable 7518 Speed Control
That is a definite YES!
I am in the process of finishing up a complete electronic retrofit of my Shopbot PRT 48 X 96 CNC Router. I installed a Super PID Kit to control the speed on my Porter Cable 7518 Router. It has excellent torque control from the minumum 5000 RPM to the maximum rated speed with good low rpm torque. I am using Mach3 with Gerry's 2010 Screen Set and PMDX Electronics.
I have attached a few pictures of the electronic equipment drawer I am presently working on. The super PID unit is in the front left side. The LED Screen is not currently connected to the yellow extension cables. The LED Screen will be incorporated into the Engraved Plexiglas LED Edge Lit panel front cover.
John
ID:	149652   Click image for larger version
ID:	149653   Click image for larger version
ID:	149654   Click image for larger version
ID:	149656   Click image for larger version
ID:	149657   Click image for larger version
ID:	149658   Click image for larger version
2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/
Old 01-06-2012, 07:27 PM
amishx64's Avatar
amishx64 is on a distinguished road
HeliJohn, that is a super cool looking setup. Got a thread?
collet add on to porter cable 7518 woodman08 Gorilla CNC Machines 10 09-30-2009 08:14 PM
Need Help!- Porter-Cable 7518 3-1/4 HP Motor Only dpot Open Source CNC Machine Designs 0 08-26-2009 03:08 AM
porter cable 7518 router hot woodman08 WoodWorking 13 10-21-2008 04:17 PM
Posible alternative to the Porter Cable 7518 joecnc2006 CNCzone Club House 4 01-16-2007 05:31 PM
Porter Cable 7518 for $250 ger21 DIY-CNC Router Table Machines 6 03-31-2005 11:45 AM
