Old 12-31-2011, 01:34 PM
jstefano is on a distinguished road
1920 x 1080 display ???
How can I get mach3 to display correctly on a 1980x1020 resolution display?
Old 12-31-2011, 02:27 PM
ger21's Avatar
The best way, is to create your own screen.
To use the standard screens, try this:
1) Maximize Mach3
2) Go to General Config, and check "Auto Screen Enlarge"
3) Close Mach3
4) Re-Start Mach3
It will be stretched out, and there will be some empty space at the bottom, but it will fill the screen. I just tested here to make sure.
Old 12-31-2011, 02:28 PM
ger21's Avatar
Also, I'm assuming you mean 1920x1080??
Old 12-31-2011, 03:10 PM
Yes 1920x1080, I tried what you suggested, no luck. I attached a screen shot.
Name:	mach3 screen.jpg‎
Old 12-31-2011, 03:12 PM
ger21's Avatar
You have Windows set to large fonts. You need to change it in the Windows display settings.
Old 12-31-2011, 03:32 PM
That made it better. Thank you
Happy New Year
Sourcing 1080 HRS killed, fine grain .187 sheets Proto Stampings Metallurgy 1 08-16-2011 06:12 PM
Southbend lathe 1920 SER# J781 help IDENTIFY jmhscout General Metal Working Machines 0 04-25-2011 05:21 PM
Need Help!- FADAL 1920-1 drawing dango Fadal 2 03-13-2010 06:22 PM
CRT/Display, '91 VF1 TheArmoury Haas Mills 0 11-04-2009 10:57 AM
Need Help!- Punching 1080 wear plate asctm General Metal Working Machines 1 06-07-2009 10:10 AM
