Old 12-25-2011, 09:01 AM
Smertrios's Avatar
Smertrios is on a distinguished road
Can a G-Code be reprogrammed?
A G12 or G13 when used in constant velocity mode can leave a little uncut material on a circle where the tool moves in a straight line to and from the circle edge because it accelerated away from the end point before reaching it.
If G12/G13 are changed to arc in and out rather than use a straight line there would be no uncut spots on the bore or circle. That and some of the drilling cycles when used in G98 retract mode dont use the R value to stop feeding when backing out of a hole. IE: they rapid down to R then feed down into the hole but then feed all the way back to the Z starting height rather than the R height.
Of course not a big deal but these are old G code issues from nearly 15 years ago when I was programming CNC's. I don't recall how but someone there modified the G12/G13 code on a Fanuc OM-C controller to make sure the constant velocity mode can be used with them to cut circles by using arc moves rather than a straight line move to get to/from the circles edge. Irrelevant for mach3 I would assume => The "problem" with canned drilling cycles was never encountered because that drilling mode wasn't used.
Not 100% sure but it may have been an M code that worked like a G code.
Old 12-25-2011, 10:29 AM
ger21's Avatar
No, G12/G13 can not be changed.
Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code nessei Fanuc 4 03-29-2011 08:39 AM
fanuc program code vs. Haas code sixty8frbrd Fanuc 6 03-10-2011 09:05 PM
Converting Fanuc G code to Seimens 840D G code Jasbinder Siemens Sinumerik CNC controls 2 02-20-2011 10:02 AM
Newbie- Takeout Unused G Code commands in Mastercams Generated G Code shneek Mastercam 8 12-15-2010 02:32 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
