Old 12-10-2011, 10:55 AM
fbmstar is on a distinguished road
"go to zero" isn't going to zero
When I press the "go to zero" button in mach 3, the dro's don't actually go to zero. This only seems to happen if the machine is close to zero at the time.
If i'm within .002" of zero, and press the "go to zero" button, the motors don't do anything, and the dro doesn't move either.
If the machine is between .003" and .040", and i press the "go to zero" button, it'll go to somewhere between .0001" and .0017". It seems random as to the number it'll stop at, but it never goes to zero. this always happens if the axis is within around .040" of the zero. If the axis is above .050" and I press "go to zero", it will always go to zero on the dro.
The steps per are 30480 on the y axis, and 20320 on x and z axis, which should give theoretical resolutions of .0000328" and .0000492".
All the numbers above are the numbers showing in Mach's DRO, not measured machine postions.
Any ideas on what is causing this?
Thanks,
Brian
"NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN" CNCadmin EBAY ADS 0 11-06-2011 01:00 AM
"Echo" or "Print" command to display to the screen? MarkSerbu Haas Mills 9 10-16-2011 12:47 PM
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
