Old 12-06-2011, 12:48 PM
RTP_Burnsville is on a distinguished road
4th Axis Motor Setup Parameters
I have a question on the motor parameter setting for a 4th axis (rotary table). What is the unit of measure for calculating the number of steps per unit of measure? Is it 1 degree as a unit for a 4th axis?
I understand the calculation for a ball-screw:
200 step motor * 10ustep of drive * 5 threads per inch = steps per unit of measure (inch in this example) = 10000 steps.
Would the rotary drive setting be:
200 step motor * 10ustep of drive * 1 degree rotation = steps per unit of measure (degree in this example) = 2000 steps.
Thanks,
Robert
Old 12-06-2011, 01:45 PM
ger21's Avatar
Is your 4th axis direct drive, or is there a gear or belt reduction?
Step/unit is per degree, but you need the gearing to calculate that, unless it's direct drive, which would be 200*10/360.
Old 12-06-2011, 04:04 PM
Thanks Gerry....
Yes, it has a gear reduction. I though about posting that but figured it would have just confused the issue.
Thanks for the info as the per degree was the part I was not sure about.
Robert
Free MastercamX setup sheets for milling free 3 axis milling active designer setup sh bigban Mastercam 1 07-26-2011 05:28 AM
DeskCNC - setup parameters maycom General CNC (Mill and Lathe) Control Software (NC) 1 12-11-2007 07:24 AM
Stepper motor parameters fabsch General Electronics Discussion 8 05-20-2007 03:47 AM
