Old 10-22-2011, 06:09 AM
jarekk is on a distinguished road
Step2Mach - DIY ethernet motion controller for Mach
Most likely only few of you read Mach support forum, so I decided to post the info here.
All details here (pictures,source code, BOM etc.):
Step2Mach - My DIY ethernet controller for Mach
I have created DIY ethernet based motion controller for Mach.
Simple replacement for parallel port ( with ethernet connectivity).
100kHz step/dir, simple and cheap to build ( 3xDIP28 parts plus 1206 size passives, possible to make on single layer PCB)
It works, currently in beta testing. I have released most of its source code, so you can play with it ( you can get full development license if you want to use it in your commercial project). For final version I will expect 35$ for plugin license - once it reaches mature level.
ID:	144498   Click image for larger version
Old 10-22-2011, 06:26 AM
Khalid's Avatar
Khalid is on a distinguished road
Thank you for sharing..I am reading in Mach3 forum..Any advantage you can post here will be useful too.
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 10-22-2011, 06:53 AM
Well, If you ask here ( on cnczone), you will get answer here ( or link to answer in Mach forum).
CSMIO/IP-S Ethernet Motion Controller (CNC) CNC support Product Announcements & Manufacturer News 1 10-26-2011 04:57 AM
Need Help!- Ethernet board for fanuc 21i MB controller ltx8d Fanuc 3 01-14-2011 05:19 PM
Is ethernet controller support with linux possible? Menatep General Electronics Discussion 3 04-25-2010 07:29 PM
Ethernet/PCI Motion Controllers 2_many_hobbies Stepper Motors and Drives 7 11-12-2009 09:50 AM
Controller parallel port connected via Ethernet (?) WoodSnarfer General Electronics Discussion 3 11-20-2004 03:48 PM
