Old 09-26-2011, 07:17 PM
judleroy's Avatar
judleroy is on a distinguished road
Animatics and Mach 3?
I am trying to setup a system using 4 animatics smart motors. From what I have read they can be setup for step/direction input. The motors are going to be setup on a laptop through 2 USB to serial adapters. Can Mach 3 be setup to send data through a USB serial converter. More importantly can it output through 2 USB ports to different motors at the same time. Any help would be appreciated. Thanks.
Judleroy
Old 09-26-2011, 08:24 PM
ger21's Avatar
Mach3 can only send step/dir signals through the parallel port.
The only way to use USB ports is to use an external motion controller, like the Smoothstepper or KFLOP.
Old 09-26-2011, 09:16 PM
judleroy's Avatar
That kind of what I'm afraid of. The animatics motors have built in motion controllers. As far as I can tell Mach 3 Would just have to send the code. I know Mach 3 works with k-motion and smooth stepper so I'm hoping to be able to integrate it with these motors. What is the issue with using a USB serial adapter? Hope someone can help me work this out so I can use the USB ports but if not I'll go in another direction. Thanks for the input Gerry.
Judleroy
Old 09-27-2011, 06:21 AM
ger21's Avatar
kflop and Smoothstepper use plugins written specifically for them to work with Mach3. Mach3 has no native USB support.
Need Help!- Tuning Animatics Smart Motors Bigrhamr Servo Motors and Drives 0 10-02-2010 08:47 PM
Constructing a THC using Animatics Smart Motor mconstrain CNC Plasma and Waterjet Machines 4 06-25-2010 01:52 AM
4 Animatics motor system modeler EBAY ADS 0 03-14-2010 12:44 PM
Help with an animatics c5200 controller sdswp5 Servo Motors and Drives 0 06-13-2008 08:57 PM
Animatics Servos And Software CRAFTY General CNC (Mill and Lathe) Control Software (NC) 0 12-30-2005 03:02 PM
