| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I finally have my BP Boss running off Mach 3 with the original steppers and drivers. I seem to be having problems with mach though on any screen but the diagnostics screen. When I am on the diagnostics screen I can feed up to 120 ipm and jog all 3 axis at the same time smoothly. On any other screen, i.e. MDI, I can only feed in one direction around 85 ipm (and not very smooth) and forget feeding more than one axis at a time. I can only get maybe 40 ipm jogging x and y at the same time. BTW, I am running with MAX CL enabled in order to utilize the existing drivers. I have the same problems running both Mach 2 and 3.
__________________ If you try to make everything idiot proof, someone will just breed a better idiot! |
| You're using MaxNC drives? Max CL mode is for MaxNC systems only. If your drives are step and direction, don't use it.
| Seems very odd, If I run anything from the diagnostics screen, MDI or load a file, it works great. Soon as I switch to any other screen it freaks out. Gonna try a different computer tonight, see what happens.
| Do you have the latest version from the website? If all else fails, email Art directly.
| I'm haveing a similar problem with Mach2... I installed the newest version and it is now giveing me 11 IPM. It used to be 14. Yes I know these are really low feeds, but thats what I get for useing a Harbor freight mill. I am useing 9.6-1 gearing just so I can move the table with 512 PPR encoders. I also had to dissasemble the drives to troubleshoot and found out later that this could demagnetize them and may result in less torque. It does BTW. I did salvage the drive though. Mach2 is @ 45000Hz |
