Old 09-12-2011, 03:23 PM
Barakathz is on a distinguished road
Soft/limit switch - 5 axis Router
How to set the soft limit/ limit switch of a Z axis fitted with B&C axis.
There are two points:
When the spindle is 90 degrees to the Z axis and
When the spindle is vertical in line with the Z axis.
There is a difference in high in both conditions,
How and which point will be considered as the max. Limit?
Can't Reset After Hitting Y Axis Limit Switch Money Pit Tormach PCNC 2 07-07-2011 08:46 PM
Arrow 1250 z axis limit switch CRABMAN Cincinnati CNC 5 05-07-2009 11:00 AM
TM-1 Y axis limit switch alarm jwknow Haas Mills 2 10-26-2007 03:53 PM
BP R2E3 S1B8 Z-Axis limit switch cidteach Bridgeport and Hardinge Mills 4 09-25-2007 09:47 PM
Y axis limit switch raytor Benchtop Machines 3 10-10-2006 08:48 AM
