Old 09-11-2011, 03:06 PM
Bradosb is on a distinguished road
Question Charge pump help
I finally got my router up and running. Everything is working and I have run a few toolpaths to test it out. My question is about the charge pump. I'm using a Gecko 540 controller. As long as I leave the charge pump off everything works fine. When I try to turn on the charge pump I can't get the e-stop to clear from Mach 3. I have the charge pump setup on pin 16 in the mach 3 software. My understaing is that as long as you power up your PC before you put power to the machine the charge pump is not needed. Is that correct?
Thanks,
Brad
Old 09-11-2011, 03:32 PM
Al_The_Man's Avatar
I don't think it was originally intended that way, but IMO it is wise to put the charge pump in the E-Stop string, this way anything at all happens to the PC stops the machine.
This is the way it is done in commercial machines.
Old 09-11-2011, 03:50 PM
How would I go about doing that? Any idea why I can't get the e-stop to clear with the charge pump on?
Brad
Old 09-12-2011, 12:37 AM
RicknBeachcrest is on a distinguished road
Not too sure I understand your problem. FWIW, this thread may help.
http://www.cnczone.com/forums/gecko_..._parallel.html
Charge Pump cadmonkey LinuxCNC (formerly EMC2) 8 04-06-2010 01:19 AM
charge pump michaelf Benchtop Machines 23 10-25-2009 05:55 PM
charge pump eloid DIY-CNC Router Table Machines 3 01-25-2009 09:14 AM
Charge Pump ??? jack55 General Electronics Discussion 6 04-21-2007 02:59 PM
Charge pump mlaws1172 Screen Layouts, Post Processors & Misc 0 01-03-2006 10:46 PM
