Old 07-14-2011, 09:40 PM
neilw20's Avatar
neilw20 is on a distinguished road
Limit switch re use of pins.
As Mach3 references each axis one at a time, can I wire OR with appropriate logic just to use a single line for all 3 axis.
This would free up 2 lines I need for a cycle start and cycle pause button.
Over travel is protected externally by a safety relay.
Machine will only run once referenced.
Inching off stuck switches will be allowed for.
THANKS GERRY. Didn't really want to pull working SX3 apart just to do the test. It is not broke, so don't want to (un)fix it.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 07-14-2011, 09:48 PM
ger21's Avatar
You can use one pin for all homing and limits, if you want.
Limit switch replacement with proximity switch? Normsthename Bending, Forging,Extrusion... 3 07-11-2009 10:38 AM
limit switch- home switch normd CamSoft Products 1 05-16-2008 06:56 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
