Backup your Mach2Mill.xml file (provided you're using mill, this has all the settings in it). Back up the screen you were changing. Uninstall and reinstall, and copy the backed up .xml over the one in the Mach2 folder.
This should get you back to where you were. You can then compare the new screen you changed to the working one.
LinkBack URL
About LinkBacks
