| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| I am sure it can be done. Has anyone made external speed and feed over-ride controls using potentiometers?
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Not sure if there is anything out there already, but it may be better to look at the common commercial O/R method of using a Binary switch, 4 bits give you 16 steps/switch. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 06-30-2011 at 12:46 PM. |
| I will design a method. Just thought there maybe a way it is typically done already. No point reinventing the wheel, so to speak. Needs to be at least 8 bits to be fine enough to be practical. I suppose you could up/down button, but that is not nice, and the latency would make it awful to use. An 8 bit switch if it must be digital. Can always make an 8 bit output A/D converter, but it will need gray code output so every step is different. Then how do you feed that into Mach3? That is a lot of bits for 2 pots, using a parallel port. USB, maybe, but will latency be an issue? I suppose an MPG type input could be made to work.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 06-30-2011 at 09:42 AM. Reason: typo |
| The easiest way is probably with a Pokeys. PoLabs - Affordable PC USB oscilloscopes, logic analyzers and USB interfaces They have analog inputs and apparently work well. Never used one, though.
| I see there is a plugin for Contec PIO boards, I am surprised that by now no one has developed a PC Based PLC for Mach using these cards. All the preferable operator hard wired functions such as feed hold and feed overide, spindle O/R etc could be done digitally this way without messing with analogue inputs etc. A resolution of 255 is hardly necessary for most overides. Al.
| The PoLabs idea looks good with the plugin, and 10 bit is more than adequate! Any other ideas out there? Now we are getting somewhere.
| Looks like you can use a ModIO as well. Touch Screen and panel controls using ModIO - MachCustomizeWiki MC-01 ModIO Controller [MC-01] - US$98.00 : Homann Designs!, The preferred CNC Component Supplier
| Tags |
| feed control, pots, speed control |
| Fadal external servo control or Haas external servo control | carbidecraters | Fadal | 12 | 09-16-2011 11:25 PM |
| Need Help!- Control Mach3 with external VB.NET program | Adamj12b | Mach Software (ArtSoft software) | 0 | 12-30-2008 09:46 AM |
| Mach3 and external PCI parallel card? | Cooper | Mach Mill | 4 | 12-11-2006 12:26 PM |
| Mach3 External Estop Reset | bcromwell | Mach Software (ArtSoft software) | 2 | 01-24-2006 10:16 PM |
| Mach3 External Estop Requested | WarrenW | Mach Software (ArtSoft software) | 5 | 12-18-2005 09:56 AM |
