Old 06-20-2011, 08:13 AM
jong664 is on a distinguished road
Configuring 'Probe' and 'Home'
Am new to this subject. Presently in the middle of converting and old Nu-Tool Mill (similar Sealey SM25).
Will be using Mach3 and 2x parallel (LPT) ports for connections.
Plan to have only 'home' switches (XYZ) linked to one input port and make use of Mach's inteligent management (one axis homeing at a time.
Am also panning to integrate MPG (ISM1468 obtained fromZapp)
Problem - Am running-out of available input ports !!
Do you think it would be possible to use the 'home' input for a 'probe' input as well ??
Thinking of wiring 'home' switches in parallel with one end on 5V pull-up and other end to ground.
This way, any 'home' switch being 'made', or the 'probe' grounded during "Auto Tool Zero" will trigger (inverted) the same input pin.
Would obviously work for 'axis-home' if 'probe' was isolated - BUT would Mach3 complain if during "Auto Tool Zero" an axis-home signal was discovered??
Any comments/guidence appreciated
Rgds.
Jon. GEORGE
Old 06-20-2011, 08:41 AM
ger21's Avatar
Mach3 would think the probe was triggered.
As long as no home switches are triggered while probing, and no probe is tripped while homing, it should work fine.
Configuring Mach3 hub Mach Mill 11 05-16-2011 10:48 AM
I figured out the home made touch probe for seanreit Tormach PCNC 9 12-03-2008 08:22 AM
Cheap home made Touch Probe. mikegasman Digitizing and Laser Digitizing 35 11-15-2007 07:18 PM
My home-made digitizing probe aolshove Digitizing and Laser Digitizing 9 11-03-2007 11:40 AM
Help Configuring Turbocnc Ayjay TurboCNC 2 03-16-2006 04:53 AM
