| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
On my techno router, when I press pause, the z axis retracts 2 inches and the spindle stops. When I do this in Mach on my home built machines it just pauses the job and the spindle keeps running. How do I get Mach to behave like the techno? To un-pause or continue a job, the techno starts the spindle and moves the bit into position. Alternatively Mach doesn't start the spindle and just continues the job from the current position without a preparatory move. How do I get the axis to move back to the paused position and start the spindle automatically?
__________________ Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3 |
| You'd need to change the Cycle Start and Feedhold (Pause) buttons to run some VB code. Have the feedhold button pause, stop the spindle, store the current position somewhere, and move to a specific Z position. The Cycle Start would need to check the status of the Pause LED. If not paused, just act like the normal cycle start. If paused, then start the spindle, return to the previous position, then Cycle Start.
| Where would I go to to learn the code required to do that?
| http://www.machsupport.com/docs/Mach...o_Prog_Ref.pdf http://www.machsupport.com/docs/VBScript_Commands.pdf Main Page - MachCustomizeWiki
| Timed pause? | fatal-exception | Mach Plasma / Laser | 6 | 03-20-2010 08:42 PM |
| Help With Arcs Pause | emvali | Bridgeport and Hardinge Mills | 24 | 09-12-2009 04:18 PM |
| Can I make Mach 2.5D or Pause for Z? | fusion_crank | Mach Software (ArtSoft software) | 8 | 03-07-2009 07:20 AM |
| Need Help!- how to pause mach 3 to wait for an input from pasma | bthomps5 | Mach Software (ArtSoft software) | 2 | 08-31-2008 11:44 PM |
| hardeware pause pause detected????? | Conquest1224 | Commercial CNC Wood Routers | 1 | 05-07-2007 10:06 PM |
