Old 05-23-2011, 07:33 PM
binfordw is on a distinguished road
Mach 3 help, Bladerunner AIO plasma
I recetly experienced some accuracy issues (lost steps?) on a long running job. I wiped my PC and reinstalled everything, Im up and cutting, but having some setting issues.
First,
I set my steps per rev to get the desired cut distance (I.E, a 4" square program cuts a 4" square), after a few test cuts to confirm things- I tried to cut a more complex part. It cut well, and seems to be sized/scaled correctly, but it was NOT where the mach3 display window said it was. I lined my part up on the edge of a sheet using the guidelines, and when cut it was off several inches in X and Y, more towards middle of sheet. Never experienced this and not sure what to do. Simple setting issue?
Also, I noticed my parts show all the cuts in different Z planes when I rotate the MAch3 view. Each cut progressively stair steps in the -Z direction..
Any help or ideas would be great,
Thanks,
Ben W
www.custommetalworking.com
Bladerunner kits ne-oublie DIY-CNC Router Table Machines 13 10-23-2011 05:53 PM
Isolated Ohmic Sensor Switch for CandCNC Bladerunner Voodoo Vintage CNC Plasma and Waterjet Machines 5 02-04-2011 03:04 PM
Bladerunner AIO Accuracy? binfordw CNC Plasma and Waterjet Machines 2 01-12-2011 05:31 PM
bladerunner soundwaves Joes CNC Model 2006 4 11-17-2008 10:18 PM
Mach Plasma? MrHorsepower Mach Plasma / Laser 2 02-01-2006 09:11 PM
