Old 05-19-2011, 10:26 PM
Guido666's Avatar
Guido666 is on a distinguished road
Machine cutting off 3D model corners on last passes
I am machining a 3D model of geographical terrain, and it completes nearly the entire model with a top-to-bottom equidistant offset toolpath, then on the very last couple passes around the base of the model the bit goes crazy and cuts off a couple inches of the bottom two corners.
I ran the toolpath through CutViewer, and it looks fine. I've attached a picture of CutViewer's output, and added red lines where it cuts off the corners on the last 3-4 passes around the model.
I'm a novice, and I'm hoping I just have something set wrong. Can anyone help?
Old 05-20-2011, 12:11 AM
Guido666's Avatar
A little more info...
It definitely has something to do with the feedrate clashing with Mach3. I ran the same program a couple more times, and full speed, and every time it would cut those corners off, around line N92000. Then I ran it again, and when it got close to line N92000, I overrode the speed to 30% in Mach3, and it finished perfectly.
I have similar other pieces of this geographical topography, and they do the exact same thing too. At the very end of the cut it chops the corners off.
Can anybody help me understand what's happening?
Old 05-20-2011, 09:01 AM
wjfiles is on a distinguished road
Go into General config page and change Mach constant velocity to exact stop.
WJF
The More I Learn The Less I Seem To Know
Old 05-20-2011, 09:33 AM
Guido666's Avatar
WJF
You think it's a constant velocity problem? Are you wanting me to try turning CV off to test if it's the cause, or are you suggesting to run the models completely with CV off?
I'd like to better understand the issue, and why it only happens on the last passes of these models. It will machine them for hours without missing a beat, then destroy it all in the last 30 seconds.
Need Help!- Gleason(Phoenix)Gear Cutting Machine Model 500HC with GE Fanuc Series 150M M.RISHIKESH Fanuc 0 10-25-2010 12:39 AM
Need Help!- CNC Cutting in Steps on 2nd and 3rd Passes tatotatito DIY-CNC Router Table Machines 6 09-26-2010 06:55 AM
cutting corners out galaxyman7 Mastercam 2 12-10-2009 07:33 PM
Rounding corners while cutting off part racingdave General Metalwork Discussion 6 08-13-2008 11:39 PM
when im doing cad, do i need to have round corners as in real model? HawainPand General CAM Discussion 10 09-11-2004 10:47 AM
