Old 05-13-2011, 03:51 AM
auswelder is on a distinguished road
Start cutting near edge?
Is it possible to start the cut near the home position, I want to start about 5mm away from the start of the x & y axis to reduce material waste.
At the moment the image in the toolpath display appears to be a considerable distance away from the home position (pink lines)
I am pretty sure it would be, just not sure how I would go about it in mach 3.
Also could it be made a default setting for future cuts.
Old 06-22-2011, 01:23 PM
ieatfish is on a distinguished road
It doesn't look like you ever received an answer here but I believe the solution has more to do with where your origin is in your CAD/CAM program and where your origin is in Mach3 on your CNC. If you have your 0,0 point in the CAD file where you would like it to be on the CNC, then when you open the file in Mach3 it will use the coordinates.
Brass build up on cutting edge larswebb EDM Machines 6 10-21-2010 05:55 PM
Just IN- New 5 Axis Water Jet Cutting Technology from Jet Edge Jetedge Product Announcements & Manufacturer News 1 09-17-2010 02:46 AM
strange edge when cutting acrylic zoefie Laser Engraving & Cutting Machines 12 08-23-2010 11:16 PM
Jet Edge Introduces Easy-to-Use CAD/CAM Nesting Software for Waterjet Cutting Jetedge Product Announcements & Manufacturer News 0 11-24-2008 02:31 PM
Jet Edge Waterjet Cutting Demos at EASTEC 2008 Jetedge Product Announcements & Manufacturer News 0 04-16-2008 09:57 AM
