Results 1 to 3 of 3
Thread: >.< Pissed with Offsets...
    Aug 2005
    can't tell you XD
    Angry >.< Pissed with Offsets...
    Hey guys out there,
    I need some help with mach 2... I would like to set offsets in two positions,
    1st offset in corner near X minus and Y minus and Z at the top of the table,
    and
    2nd offset in somewhere else the table(still not sure where to put)
    I would want it to run the 1st offset when I start mach2 and after a cutting process. For the 2nd offset I want to place where it's easy to do some repairing/replacing/maintaining service for the router.
    I've read the thread about "How to set up Tool Offset in MACH2?" and I couldn't tweak the Mach2 as I don't know where to tweak the offsets though it's mentioned...
    Someone Please, Help me!!! I'm new to Mach2!!!!
    Gold Member
    Jun 2003
    Do you have home switches? if so, the homed out position is G53, you can set up G54, G55 G56 etc off of the home position. when you home it out you want to set the settings to zero the axis' when homed. then you go edge find, switch to the first offset or what you want and touch it.(in the offsets tab) The z-axis shoudl be set in the tool table.
    When your cutting going from one offset to the other(lift to a safe z to clear stuff)
    G0 Z.1
    G55
    G0 X Y
    pretty simple overall
    Jon
    CNC Mini Lathe Plans and Rotary Table kits:
    http://jfettigmachines.com
    Aug 2005
    can't tell you XD
    Okay, I'll try it out. I'll tell you the results when I'm done. Thanks, JFettig.
