| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hi to all. I've just down loaded Mach2 for evaluation and would like to simulate a milling process. I haven't regisered it yet, so it will probably have some operating limitations. I have tryed to import a 3D IGES surface file to create a cutting path but was only able to import in DXF format. Could anyone who's used this software (or maybe Art Fenerty) kindly tell me if this is either a limitation of the evaluation package or if these (HPGL, JPG, BMP and DXF) is the actual range of formats that may be imported for cutting path creations? cheers
__________________ Martin G |
| An Iges surface conversion is very advanced for a $150.00 G-code interpeter. Use a CAM package to create the G-code and then use Mach 2 to run it.
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Hi Jeff, as you might have already anticipated, I've got no experience with this software, so this imposes 2 questions. 1.) How does the software recognize the limits to which one requires to cut, particularly on a dome shape, since DXF is only a 3D wire frame (as far as I know and please correct me if I'm wrong) and 2.) How can the software determine which side one desires to cut? Or is there an option to chose? Judging from what I have seen while configuring it, I have to disagree to your reasoning one reason that comes in mind is the ability to anticipate gouging areas.
| How do i get my autocad file onto mastercam? | EdE | General CAM Discussion | 3 | 02-23-2011 12:54 AM |
| Emco Compact 5 PC...have ???? | Double G | Mini Lathe | 42 | 08-22-2010 07:26 PM |
| Boot disk for EZ-Track DX, batch file? | mmm2003 | Bridgeport and Hardinge Mills | 8 | 01-31-2007 12:47 PM |
| Backup Script.. | Rekd | Mastercam | 3 | 09-11-2003 10:34 AM |
