| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Well,I have some strange problem with my diy desktop cnc. Had some problems with calibrating Y axis,just could not get it right.On X and z axis did not had any problems,just my Y axis... After a lot of work on mechanical parts discovered this strange problem. When moving it manual (joging) it works flawless,but when comanding it from g-code(for example:G0Y150) motor after 3-4 seconds makes some strange noise,glitches for a moment and then continues rotating. Sometimes it stalls but very rarely. This tests are made with motor separated from the machine(leadscrew). Tried switchin the drivers,same thing happens,also switching the motors makes no diference. Even changed parallel port pins for that axis but no difference. HELP please,because this cnc hoby is slowly becoming nightmare...
__________________ http://zeed-diyproject.blogspot.com/ |
| If the motor is mounted to the machine, it could be resonance. Resonance can be worse with the motor not connected to the screw. Try attaching the screw and see is it's better.
| Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor | Bordaco | Servo Motors and Drives | 4 | 09-08-2011 05:41 PM |
| Stepper Motor "cogging" issue | TravisR100 | Stepper Motors and Drives | 18 | 05-16-2009 09:21 AM |
| AMC amps cogging | ka67_72 | Servo Motors and Drives | 11 | 12-02-2008 08:31 PM |
| Need Help!- Motor Cogging | offthewall | Stepper Motors and Drives | 7 | 05-04-2008 04:42 AM |
| need to replace my large 1200oz-in steppers with smaller one with less cogging/detent | Apples | Stepper Motors and Drives | 9 | 02-15-2007 01:34 PM |
