| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hello Everybody. I know this problem is old but I did not find. In Mach 3 I have 2 limit switch for Y and share the same pin. I set one of the limit switch to be home position. Works fine. The problem I have I want after referencing the axes the machine to move 2-3 mm away from the switch. This tings will help when you jog the table to not hit accidentally the limit. Any help please Sorry about poor English is not my native language. Thanks Alexandru |
| You only need one switch on either end of axis for homing/limit. It is best to use seperate pins for the setup in mach for each switch. Mach will use same switch for both uses with no problem as long as your setup is correct on the inputs setup page of mach.
__________________ Don IH v-3 early model owner |
| Change the ref all home script to this. The Y will move 3mm after homing. DoButton( 24 ) DoButton( 23 ) Code "G53 G0 Y3" While IsMoving() Wend DoButton(22)
| Home Limits | kolias | DIY-CNC Router Table Machines | 3 | 06-05-2009 09:12 AM |
| Switch Limits | jarpo82 | General Electronics Discussion | 2 | 09-18-2007 02:07 PM |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
