Old 03-17-2011, 07:47 PM
jsheerin's Avatar
jsheerin is on a distinguished road
Lost xml file settings after upgrading mach
I upgraded my mach3 install last week from 3.042.035 to 3.043.022. Started up the new version and cut some parts - no problems. I turned off my computer and it sat for a week (this computer is only for my router - nothing else is on it). Tonight I started it up and all my settings were gone - motor tuning, ports and pins, etc. I tried a backup .xml file from the backup directory, but that didn't work. Then I found an old copy of my .xml file I'd saved from over a year ago. That worked, although I think some of the settings are not where I had them more recently. But why did my .xml file disappear and lose all my settings? That's never happened to me before when I upgraded mach (and it didn't even happen immediately after I upgraded). Any one else have this problem?
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Old 03-17-2011, 08:08 PM
ger21's Avatar
I had mine get corrupted the other day and had to create a new one from scratch. Mine was due to a PC lockup caused by noise.
But I've seen others lose there .xml settings, many times over the years. I don't think anyone really knows why it happens.
What I did this time is make a backup as soon as I had all my settings correct.
Another option is this program from Klaus, that will make a backup and restore you settings.
Profile comparison and port pin check
Old 03-17-2011, 08:18 PM
jsheerin's Avatar
Thanks Gerry. I'll just go through my settings and try to remember what I had, then make a backup.
Upgrading to the latest Mach version watsonstudios Mach Software (ArtSoft software) 4 06-19-2009 08:04 AM
Waaah! I lost all of my Mach3 mill settings BrassBuilder Mach Software (ArtSoft software) 6 10-27-2008 07:37 PM
Thinking of upgrading to MACH - What should I expect Hack Work Fixtures and Hold-Down Solutions 3 11-26-2006 07:27 PM
Bridgeport Discovery 308 SX-15 CMOS lost time and settings Richardd Bridgeport and Hardinge Mills 5 06-23-2006 07:53 AM
Bridgeport Discovery 308 SX-15 CMOS lost time and settings Richardd Machine Problems, Solutions , Wireless DNC, serial port 0 06-22-2006 07:01 PM
