Results 1 to 3 of 3
Thread: Auto defining of Motor Pins in Mach 3
    Jun 2009
    I have had a computer crash and now starting from sctatch. I did not write down my motor ports and pins. I remember the Mach 3 has a way of telling you which port and pin each motor is hooked up too. How does oen do this. I cannot find it again in Mach 3 anywhere??
    May 2008
    This is not possible.
    The only auto detect in Mach3 is on the inputs
    It will detect when you press a switch connected to the parallel port.
    It is impossible for mach to know what port and pin you motor are.
    Jeff
    Jan 2005
    Barefootboy4
    If you have the XML file that will get you going, & do what you want to do
    Mactec54
  1. Output pins in Hobby CNC PRO BOARDS and Mach 3
    By Rene Nuņez Paz in forum Hobbycnc (Products)
    Last Post: 06-01-2010, 08:59 PM
  2. Need Help!- AUTO TOOL ZERO WITH MACH 3
    By feragto in forum Mach Wizards, Macros, & Addons
    Last Post: 12-12-2009, 01:49 PM
  3. Pulse Motor for Auto Feed?
    By EvilSmirk in forum Mini Lathe
    Last Post: 09-15-2009, 11:48 AM
  4. the motor rotates in jog but no in auto
    By PRIOR666 in forum Fanuc
    Last Post: 06-28-2007, 03:03 PM
  5. Confused in Mach 2 enable pins config,it's mapping to XYZ or not?
    By szcharle in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-15-2007, 06:23 AM
