| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
does anyone find mach3 unreliable? I am thinking of converting my Anilam 1100 to Mach3. I've heard of it doing some funny thinks like crashing a mill into the table out of no where type things? Also I was also thinking of going the EMC route seems a lot cheaper option since I have -+10VDC servo motors already. RLC |
| Been using it on my hobby cnc for over 2 years with never a problem with Mach3 itself. I did have one PC that caused Mach3 to do some extended moves once started, but I tracked it to a rouge .dll that had nothing to do with Mach3. (other than to make it act strange) After that I did a clean install of XP and only enable what I needed to run Mach3 in XP and BIOS. Have never had that problem since. |
| If you are having reliability issues the first place I would look is your PC. I have loaded and tested Mach3 on over 20 machines ao various shapes and sizes. I build all my own machines so I know exactly what parts work and what parts cause problems. For instance many Gigabyte (brand) mother boards play havic with Mach3. All kinds of skips and jumps. I have found the same mother boards will cause clicks and pops when playing audio so its some sort or IRQ or timeing problem. I have run windows XP but now strictly use windows 7. I prefer boards with build in parallel ports as only a few of the add on boards actualy work correctly. Never, I repeat never use mach3 on a laptop. You are just asking for problems and if it does not have a proper parallel port it wont work at all. Dont run mach 3 on a server that is running web or FTP servers or anything similar. They can also play havic with the timeing. I use mostly little ITX mother boards with Nvida chip sets and tend to stay away from AMD. The slowest machine I run mach3 on is a little dual core 1.6Ghz. The fastest is a quad core 3Ghz. I have run it on my CAD workstation which is Quad 4ghz. I have run two parrellel ports with success. One Built in and the other an add on. This way I could control two G540's. The charge pump only worked on one though. I have written software to talk to mach3 and directly load Gcode. Works well once you get mach3 installed properly. |
| laptop is about 8 years old... Darren |
i have been using mach3 on a diy lathe since a year. But mach never gave me an unwanted move. Yes, once there was some problem in the leads of an axis but it was a bad DIR pin on the parallel port. now i keep the things on add on pci parallel cards and if i face an issue i put another one first of all. they are really cheap (5$ each) so i keep two or three in spare. The best thing is to keep a backup of the xml file in your mach3 folder. If you are having a new problem, try restoring the older settings to make sure that things work like before again and then redo the changes you want. I have seen some people using mach on machines having 12kw spindles and 1.5 kw servos so you should not be worrried about it. One suggestion from me- if you are wiring the inputs outputs first time, use an isolated bob. (on board port is always priceless) jasminder singh
__________________ It is better to die for something than to live for nothing. |
__________________ Regards, Carl |
| the only issue i have with it is the documentation/wiki/videos are very out of date. Not good for software that has a pretty steep learning curve. The support is spread out between its own forum, a yahoo group and this forum on cnczone. other than that ive never had a machine go crazy on it. ive broken some bits on machine extents due to my own fault. The documentation really lets this product down, the mach wiki is hideously incomplete. |
#10
As far as laptops are concerned, there are plenty of options out there for using mach without a printer port. And as far as ftp or web servers. you must be using old dodgy hardware. the drivertest program is there for a reason. If you want to run other apps/servers/whatever, load them up with usage and run the drivertest program, if your getting spikes then your hardware cant handle it. this is just another example of a point i made earlier about sloppy documentation on mach, and the absence of unified hardware list. All that exists is anecdotal evidence spread out on 3 forums. |
#11
| Actualy I found the problem on the Gigabyt boards. You have to dissable the CPU Speed adjustment so that it runs at full speed all the time. This fixes the Mach 3 problem as well as the Audio clicking I mentioned. (The two were related). And I will agree that some laptops will run Mach3 just fine, many wont. I own three and two of them suffer from timing problems. Im not going to get into an aruing match over what will and will not work with Mach3. I will simply state the facts. For the easyest and most reliable way to control a CNC with Mach3 is to use a PC with a built-in Parrallel port. Anything else adds complexity and/or reliability issues. |
| Need Help!- Where to find Mach3 turn .set layout file | LTP | Mach Lathe | 3 | 01-01-2011 08:36 AM |
| Differences Between Mach3 Mill and Mach3 Plasma? | cjjonesarmory | Mach Plasma / Laser | 0 | 11-18-2010 09:12 AM |
| TL-2 (how to find used) | behindpropeller | Haas Mills | 1 | 04-19-2010 10:09 PM |
| Where to find | LaserImage | General Metalwork Discussion | 0 | 04-15-2009 02:27 PM |
| Looking to find a home for a Bridgeport Series 1 CNC (was BOSS 5, now Mach3) | bbuonomo | Bridgeport and Hardinge Mills | 3 | 02-20-2009 07:35 AM |
