Old 02-21-2011, 03:21 PM
kievari is on a distinguished road
Mach3 fail, forward works, backward failed
Today I received the cnc machine I ordered from China (the model is called 60400). I installed Mach3 and passed config. menu setting. In Input signal setting, successfully set up the Emergency signal button of the control box. After all setup, I can forward the motors, but backward button on the keyboard does not do anything. That is to say, X+ works, but X- does not! (Left arrow moves the motor, bat right arrow does nothing).
If I enable direction low from config. menue, then the inverse happens: again the keyboard moves the motors in only one direction.
It is first time in life I've installed Mach3 and met a cnc machine! I tried various settings but can't get out of the problem.
Could anyone please give some idea? May be I must provide more information? If so, what should I add please?
Mach3 works at seller's shop, but not at home.. Catharsis Mach Software (ArtSoft software) 3 01-25-2011 12:51 PM
Need Help!- Controller works with Mach3 but on EMC2 it wont work but other mill does so ? Tkamsker LinuxCNC (formerly EMC2) 14 10-26-2010 11:00 AM
why are posts backward? packrat CNCzone Club House 2 01-21-2010 11:13 AM
Works in KCam, Not working in Mach3 Cooper Mach Software (ArtSoft software) 2 03-11-2007 11:41 AM
Forward Controls raceshop General Metalwork Discussion 5 01-05-2007 10:48 AM
