Old 02-13-2011, 09:53 AM
mark.a is on a distinguished road
mach 3 keeps stopping
im hopping someone can help. when i am running mach 3 the cnc stops moving, the code is still running on mach but no motor movement.
if i shut down mach then restart the motors will run again.
any help would be great.
Old 02-13-2011, 10:07 AM
Senna's Avatar
Senna is on a distinguished road
It would be helpful if a bit more info was supplied.
What version of Mach3?
Is this a licensed copy?
Does machine movement stop at the exact same location each occurrence?
OR do you get further along on a cold machine and stops occur more quickly when warm?
How about vice versa... machine goes further in the code when warm vs cold?
More info would certainly help us help you...
Steve
aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
Old 02-13-2011, 10:17 AM
version r1.83.027
yes it is licensed
i havent really noticed wether it stops in the same place all the time
i dont think it does. dosnt seem to make a difference if it has been on for a while.
i am running windows 7 32 bit
hope this helps if you need any more info just ask. many thanks
Old 02-14-2011, 02:11 PM
just an update.
i ran the same code today when the pc was first turned on so everthing nice and cold, went through complete code without stalling. sounds like the driver board may have overheated and shut down.
one other thing i found was when i did the original drawings i used google sketchup. when you draw a circle you have to tell it how many segments it is with a max of 999, when you convert it to run in mach3 it produces 999 codes for a circle. i think this may have had something to do with it.
Old 02-16-2011, 10:54 AM
Senna's Avatar
With the success you had at cold startup I'm thinking the problem is NOT with Mach3... but electronics... most likely in the controller.
These types of problems can be frustrating to hunt down... one way to eliminate Mach from the mix is to run code without having your machine on. If Mach digests your code with full runs... it can be eliminated as the source of your issue.
Good hunting!
Steve
Old 02-17-2011, 01:44 AM
i think you are right senna i have a cheap chinese controller, with the help of
GrootWitBaas i have managed to modify the board to stop it missing steps. he also adviced me to remove the heat sink fan which seems to be the culprit (drawing to much current) been running a lot of code since with no problems. fingers crossed. by the way i have a 4" 240v fan now colling the whole board.
Old 02-17-2011, 09:42 AM
Senna's Avatar
Good deal... I'm rooting that you have vanquished the gremlin. Happy cutting!
Steve
Old 02-21-2011, 11:31 AM
well the problem is still their. while running code the cutter keeps stopping tried changing the kernell speed to see if that made any difference. the only thing that happend when i changed the speed it would start again, so i dont think it is the board overheating.
the other thing is when the axis stop moving and you try and use the jog buttons you can hear the motors jerking a little.
all in all its starting to get irratating especially when your half way through a cut.
Old 02-21-2011, 12:38 PM
restless1 is on a distinguished road
can you load mach3 on an xp machine and try it?
Since you have a licensed version why don't you upgrade to the latest I believe its free upgrade from a licensed version.
the latest version is Mach3Version3.042.040 and yours is woefully old..(with lots of bugs..
If your having problems upgrading mach3
Send a copy of your license to license@machsupport.com
and ask them to help..
Old 02-21-2011, 04:30 PM
ger21's Avatar
Originally Posted by restless1 View Post
the latest version is Mach3Version3.042.040 ............
3.42.040 is not the latest anymore. But you can get it from the ftp site
Have you run the drivertest, and if so, do you get a flat line?
When the machine stops moving, open Task manager and see what the cpu load is.
  #11   Ban this user!
Old 02-21-2011, 06:38 PM
thats what i get for looking to quickly lol..
  #12   Ban this user!
Old 02-22-2011, 02:15 AM
just tried downloading that version it got about 5mb then stopped.
i have been onto their web site they have a version Mach3 R3.043.022
do you no if this is a full working version.
Need Help!- Spindle not stopping adaptaflex Fanuc 4 08-17-2010 03:03 PM
spindel stopping mid job jessec SprutCAM 2 12-07-2009 11:04 AM
stopping? nelZ CamSoft Products 2 11-06-2009 05:00 PM
VF2 keeps stopping donj1 Haas Mills 16 08-11-2005 10:09 PM
