Old 01-30-2011, 04:02 AM
georgebarr is on a distinguished road
mach3 programming
Is there a way to make Mach3 config settings directly from gcode? Sometimes I forget to set the Config > General > IJ Mode to "absolute". I would like to get this done automatically when the gcode runs. I recall that VB scripting (I think) can be used.
Is the above possible?
Old 01-30-2011, 04:34 AM
jalessi's Avatar
jalessi is on a distinguished road
Georgebarr,
Try this and see if it works for you.
G90.1 = IJ ABS, G91.1 = IJ INC
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 01-30-2011, 07:54 AM
ger21's Avatar
Just a note, that if you have a G90 or G91 at the start of your g-code, the G90.1 needs to be on a different line, or it won't work correctly. The two conflict with each other.
I start my code like this.
G20 G40 G90
G91.1
M6 T1
S10000 M3
Old 01-30-2011, 04:14 PM
I already have G90 (absolute), but was not aware of G90.1 (absolute for IJ). Do these two have to be on different lines? Someone says G91 and G91.1 do need to be on different lines.
How about tool length offset:
G43T10
G2Z1H10
There are the T and H. Since I do not use tool length offset, I plan to program my Powermill post processor to remove the T and H commands. Will that be OK? I of course use G49 (cancel tool offset).
How about Fixture offset: G54 to G59? There is no "cancel fixture offset" G command. I do not use fixture offset. If by default it is set to G54 and Mach3 has fixture offset information on G54, then how can I cancel this. Or, how can I zero out the G54 offset information from gcode?
Thanks,
Old 01-30-2011, 04:40 PM
ger21's Avatar
Yes, you need to have them on different lines.
G90
G90.1
You need to use
G43 H10
You don't use the T there.
I think you'll get an error trying to use
G2Z1H10
I don't know how to zero G54 from G-code, or if it's even possible. You can easily crete an M code macro to do it.
You might also want to use G92 instead.
Old 01-30-2011, 04:57 PM
I found this searching the internet.
G92.1 (cancel global offset)
G10 L1 P3 Z0 A0 X0 (set tool #3 to have zero height (Z), zero tool tip radius (A) and zero diameter (X))
Not sure how to set tool diameter offset to zero.
G10 L2 P3 X0 Y0 Z0 (Set fixture #3 to 0,0,0 offset)
I tested the two G10 above in Mach3 and they do work.
With the above, I do not have to get into the more complicated M code macro or scripting.
Thanks,
Differences Between Mach3 Mill and Mach3 Plasma? cjjonesarmory Mach Plasma / Laser 0 11-18-2010 09:12 AM
Newbie- Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder router101 General CNC (Mill and Lathe) Control Software (NC) 3 11-03-2010 04:46 PM
Programming Mach3 by just jogging the axes manually uplb Mach Software (ArtSoft software) 3 11-14-2008 08:06 PM
need programming help Joe Miranda Milltronics 1 10-04-2008 07:08 PM
Cnc Programming Course millmonkey1 G-Code Programing 0 02-20-2008 02:54 PM
