Old 01-24-2011, 03:41 PM
Barefootboy4 is on a distinguished road
Import DXF files directly into Mach 3???
How the heck does one Import a simple scribe outline line for a wing into Mach 3 directly. I milled a mold for a DLG glider which is fine but now want to make a tool change and V-tool scribe the trailing edge of the wing. I'm running Vectric Cut 3D which will not see the line because it's not 3D. I looked in the Mach 3 manual and it says to look in the file menu for direct DXF import but I do not see it. It's a simple poly line so it should work. Any help out there???????????????
Old 01-24-2011, 03:54 PM
ger21's Avatar
The .dxf importer is long gone. You need to use LazyCAM, which replaced it, or a 2D CAM program.
Problem- Import/Export Files between Rottler P69 and F68A soporte General CAM Discussion 0 07-04-2010 05:12 PM
How to import ProE files in Solidworks Tony888 Solidworks 9 07-02-2009 11:05 PM
Need Help!- Import/Convert DXF or PLT files to Mach3.... Mikael Mach Mill 3 12-25-2008 03:33 AM
mach 2 import image gilligan Machine Created Art 3 11-22-2006 05:22 PM
VBA - Import & Split large files NeoMoses Visual Basic 0 11-12-2006 02:38 PM
