Old 01-24-2011, 03:34 PM
Barefootboy4 is on a distinguished road
Work offset question
I know this is a basic question but when I saved a work offset in Mach 3 and gave it a name how do I retreive it??. The work material is indexed to the table with two pins so I can do more than one run. I'm not sure the process to get back to the saved work offset whan I have changed the cordinates for something different. Any help out there.
Old 01-24-2011, 03:58 PM
ger21's Avatar
I know this is a basic question but when I saved a work offset in Mach 3 and gave it a name how do I retrieve it??
A more important question, is how did you give it a name?
Work offsets are numbered, G54-G59, then G59P7 -G59P254.
They are stored in a tanle. When you save the offset, you save the table. You can't give it a name.
Old 01-25-2011, 11:07 AM
OK, Now I understand! Just know the G# and go back to that. Got it
Thanks again for your help
Need Help!- Work/toolpath offset-Question.. CyborgCNC Mastercam 3 03-14-2010 03:42 AM
Need Help!- work offset Claude Boudreau BobCad-Cam 3 11-22-2009 05:41 PM
Newbie- Daewoo EZ-Guide Work Offset Question. kjetton Daewoo/Doosan 2 05-28-2008 06:53 PM
Work Offset Question Cartierusm Mach Software (ArtSoft software) 17 11-29-2007 03:50 PM
work offset in fanuc 6m b- help rags Fanuc 14 08-03-2006 09:39 PM
